I have installed SDK 3.1.2. When I double click on the "snip.scan-BCM943362WCD4 download run", I get the followig erros:
(Cannot run program "C:\Users\naderk\Documents\WICED\WICED-SDK-3.1.2\Wiced-SDK\make.exe": Launching failed)
The WICED SDK version is: WICED Version: 3.1.2 e9f1fea5e98ed6220fa4005d8bf10231f2656b72
Any idea?
Nader
It works now.
The problem was on the SDK. Apparently I had to delete the old and the new version and reinstall the new version.
Nader
MichaelF_56
Can you run any other Snips within the SDK?
Have you verifed that the FTDI drivers are installed correctly (look in device manager and watch them enumerate when you plug the board in),
None of them are working.
I checked the Device Manager and I see the following with no error:
[cid:image003.png@01D09893.D119FC60][cid:image004.png@01D09893.D119FC60]
Unplug the board from your Windows machine.
Delete those stray, unknown USB drivers from Device Manager.
Open a command shell under Windows and navigate to: /Wiced-SDK/tools/drivers/BCM9WCD1EVAL1_Drivers/dpinst.exe
You should be able to reinstall the drivers.
jaeyoung
Are you talking about the following?
[cid:image002.png@01D09898.DFB5F800][cid:image003.png@01D09898.DFB5F800]
It works now.
Nader
