I have been trying to get the snip.email to work with the Quicksilver board. No matter what RECIPIENT I try, I get Sending email….FAILED! I changed the sending email account to my personal account (that why the SMTP server for mail.hover.com) which was what was recommend when I looked on the community to see if I could find an answer and that didn’t help. There is not much information to go by to debug what the issue is. It is when it tries to to the wiced_smtp_send
WPRINT_APP_INFO(( "Sending email ... " ));
if ( wiced_smtp_send( &account, &email ) == WICED_SUCCESS )
WPRINT_APP_INFO(( "success!\n" ));
else
WPRINT_APP_INFO(( "FAILED!\n" ));
Starting WICED vWiced_006.002.000.0072
Platform Quicksilver_EVL initialised
Started ThreadX v5.8
Initialising NetX_Duo v5.10_sp3
Creating Packet pools
WLAN MAC Address : B8:D7:AF:28:8E:9E
WLAN Firmware : wl0: May 15 2018 19:39:17 version 7.15.168.114 (r689934) FWID 01-d6f88905
WLAN CLM : API: 12.2 Data: 9.10.74 Compiler: 1.31.3 ClmImport: 1.36.3 Creation: 2018-05-15 19:33:15
Joining : MFR Arrow iPhone
Successfully joined : MFR Arrow iPhone
Obtaining IPv4 address via DHCP
DHCP CLIENT hostname WICED IP
IPv4 network ready IP: 172.20.10.3
Setting IPv6 link-local address
IPv6 network ready IP: FE80:0000:0000:0000:BAD7:AFFF:FE28:8E9E
Fetching time from the SNTP server. Kindly wait... Current time is: 2018-12-01T00:04:09.747000Z
Querying DNS server for mail.hover.com
Successfully retrieved SMTP server IP : 216.40.42.134
Sending email ... FAILED!
Wi-Fi Direct
WICED Studio
Hi Mike,
I also have a normal gmail account I think. I can see the less secure apps option by following this sequence: Account > Sign-in&Security >
Apps with account access and then look for Allow less secure apps, you should be able to get it. In case the issue is still persisting, the best way to go about this is by looking at the failure code or going into debug mode
You can just check the return as shown below to pinpoint the exact error. If it is error 4, that means it has something to do with the way the e-mail clients' settings
res = wiced_smtp_send( &account, &email );
WPRINT_APP_INFO(( "FAILED with %d!\n",res ));
