I am using snip.config_mode as a starting point or my project and want to use a local wifi_config_dct.h file. I modified config_mode.mk to include the line
WIFI_CONFIG_DCT_H := wifi_config_dct.h
and everything builds as expected.
The problem occurs when I run it. When the default_wifi_config_dct.h is used the program works as expected, the web server is started and it acts as a soft ap, when the local copy is used, the program tries to join the the SSID defined by CLIENT_AP_SSID in the wifi_config_dct.h file.
The problem seems to occur in the function wiced_configure_device() when it calls wiced_dct_read_lock() getting the device_configured state. When default_wifi_config_dct.h is used, device_configured returns WICED_FALSE, when the local copy (an identical copy) is used WICED_TRUE is returned.
What am I missing? Is there a document I should be reading?
Thanks in advance
DCT
softAP
Web Services
I could reproduced it.
If we add WIFI_CONFIG_DCT_H into Makefile,
SDK automatically sets "device_configured" as WICED_TRUE.
Please refer following files for detail.
<WICED-SDK>/tools/makefiles/wiced_config.mk
<WICED-SDK>/WICED/internal/dct.c
Anyway, snip.config_mode is a sample for Wi-Fi configuration and etc.
So you don't need to use local "wifi_config_dct.h" with it.
If you want to use pre-defined configuration,
please refer other samples like apsta, http_server_sent_events.
It looks strange.
So let me check one thing.
I think you just add/remove one line below in config_mode.mk.
Then do you "clean" before building "snip.config_mode-xxxx"?
Yes, I only added the one line and did a clean before building.
Adding rashijain and abirjepatil from the WICED applications team.
Thank you for your answer. Unfortunately the apsta and http_server_sent_events do not fit my needs as config_mode does. I will simply modify <WICED-SDK>/WICED/internal/dct.c. I realize this is not the best solution but it is one I will deal with.
Thank you again for your response.
-- Ken
I know this is old, but hypothetically if I wanted to have a custom wifi_config_dct.h file AND make the configuration app run what would be the appropriate way of doing it?
So how would we make the SDK NOT automatically set "device_configured" as WICED_TRUE?
