sflash_write error fix, SDKs -all.
Simple 2 lines error correction to resolve page write error at free address . This error I reported her: Possible OTA bug?
int sflash_write( const sflash_handle_t* const handle, unsigned long device_address, /*@observer@*/ const void* const data_addr, unsigned int size )
int status;
unsigned int write_size;
unsigned int max_write_size = (unsigned int) 1;
int enable_before_every_write = 1;
const unsigned char* data_addr_ptr = (const unsigned char*) data_addr;
unsigned char curr_device_address[3];
uint8_t result;
if ( handle->write_allowed != SFLASH_WRITE_ALLOWED )
return -1;
/* Some manufacturers support programming an entire page in one command. */
#ifdef SFLASH_SUPPORT_MACRONIX_PARTS
if ( SFLASH_MANUFACTURER( handle->device_id ) == SFLASH_MANUFACTURER_MACRONIX )
max_write_size = (unsigned int) 128; /* TODO: this should be 256, but that causes write errors */
#endif /* ifdef SFLASH_SUPPORT_MACRONIX_PARTS */
#ifdef SFLASH_SUPPORT_SST_PARTS
if ( SFLASH_MANUFACTURER( handle->device_id ) == SFLASH_MANUFACTURER_SST )
#endif /* ifdef SFLASH_SUPPORT_SST_PARTS */
#ifdef SFLASH_SUPPORT_EON_PARTS
if ( SFLASH_MANUFACTURER( handle->device_id ) == SFLASH_MANUFACTURER_EON )
#endif /* ifdef SFLASH_SUPPORT_EON_PARTS */
#ifdef SFLASH_SUPPORT_MICRON_PARTS
if ( SFLASH_MANUFACTURER( handle->device_id ) == SFLASH_MANUFACTURER_MICRON )
#endif /* ifdef SFLASH_SUPPORT_MICRON_PARTS */
if ( enable_before_every_write == 0 )
status = sflash_write_enable( handle );
if ( status != 0 )
return status;
/* Generic x-bytes-at-a-time write */
while ( size > 0 )
write_size = ( size > max_write_size )? max_write_size : size;
#if 1//darius, correcting write_size to properly write page block
if( ( (device_address & 0xFF)+write_size-1) >= 0x100)
write_size = (unsigned long)0x100 -(device_address & 0xFF);
#endif
curr_device_address[0] = (unsigned char) ( ( device_address & 0x00FF0000 ) >> 16 );
curr_device_address[1] = (unsigned char) ( ( device_address & 0x0000FF00 ) >> 8 );
curr_device_address[2] = (unsigned char) ( ( device_address & 0x000000FF ) >> 0 );
mwf_mmfae wrote:
Thanks darius1
Do you review the code and confirm the change is correct?
I do appreciate darius1's work, but I hope someone from cypress can review the code and confirm if this change is correct or not.
Is there any review update about that issue? I have tried 100+ trials with and without these 2 lines, but results were the same.
Hi.
This issue are critical if you using spi flash chip with page write function - exmp.: MACRONIX_PARTS or MANUFACTURER_MICRON. I use MACRONIX. So, for me was big problem.
If you use SFLASH_MANUFACTURER_SST or SFLASH_MANUFACTURER_EON you can leave this fix or not.
What your spi flash chip?
Thank you for quick reply,
I am using WINBOND 25080 bla bla something.
WINBOND 25Q80 chip have page write function. So , I think, for you are critical.
The point is no one from cypress to review the patch post on the forum.
I don't know what's your meaning by marking this as helpful.
Is that a confirm this is a good fix? AFAICT, you deliver a confusing message.
Darius response was helpful. I'm entitled to an opinion.
What could be the reason to not make any difference between my tests with and without your fix? I tested over 100 times and all OTAs was successfull in two case.
Hi
Read this
After 7 update with new firmware file (each file bigger 4096 byte) your system will crash.
At 7 step new header address became xx 0xFE . Write to this address succses only 2 bytes other 32 bytes are writed into start of page... so your header became fail. After reboot bootloader load new corrupted data into your main application place and crash...
Sdk not supported winbond.. so you must write support for this chip. What is max_write_size in your function sflash_write?
Note. After 9 step your system will crash anyway..
Other situation, which was for me - firmware update chunk size. I used chunk size 130 and writing into sflash was failed. If chunk size is 2^n then old fuction writing ok.
Hi darius1,
Thanks for point out this issue and provide the fix.
I think the issue is *valid*.
You change means a write cannot cross 2 pages, I think the fix is correct.
Thought I don't like the hardcoded 0x100 and 0xFF values, but it looks correct to me if the page size is 256.
Axel
Thank you for your review.
#if 1//
#define PAGE_SIZE 256
if( ( (device_address %PAGE_SIZE )+write_size-1) >= PAGE_SIZE)
write_size = (unsigned long)PAGE_SIZE-(device_address %PAGE_SIZE);
#endif
