Feb 09, 2021
10:26 PM
Feb 09, 2021
10:26 PM
I try to mirigrate from 6.4 to 6.6 and this not working.
The new project (6.6) wut the same code were compiled but stuck in spi init funciton.
What I need to know to this mirigrate?
Labels
PSoC general
- sdk 6.6
Mar 09, 2021
03:50 AM
Mar 09, 2021
03:50 AM
It seems that you're trying to run the same code example in 6.6 that is compiling successfully in 6.4 and you're not facing any issues in 6.4 but you're facing issues in 6.6 with the same code example, right? Are you trying to run the code in the debugger mode? If yes, have you done the debugger configurations in 6.6? I'm attaching a document that you can follow to do debug configurations correctly and your debugger will run fine after that.
Aditi
