AxLi_1746341
Level 7
Level 7
10 comments on KBA 5 comments on KBA First comment on KBA
Running scan snip code for a nearby AP with WPA2 AES enterprise security, got below output:
2 Infra BA:55:10:CF:AA:D0 -48 144.4    6     AES Enterprise       TEST-WPA2-ENT                             PROBE
It shows "AES Enterprise" rather than "WPA2 AES Enterprise".
I'm not sure if this is intentional but this seems wrong because
"AES Enterprise" is not a valid wiced_security_t.
I would expect "WPA2 AES Enterprise" in this case.
Hello:
seems we missed the WPA2 set in enterprise mode, please modify below setting in wwd_wifi.c for a try .
            if ( akm_suite_list_item == (uint32_t) WICED_AKM_8021X )
                record->security |= WPA2_SECURITY;  //add this line
                record->security |= ENTERPRISE_ENABLED;
Zhengbao_Zhang
250 sign-ins First comment on KBA 10 questions asked
Hello:
  I have a check on the print functio, it shows WPA2 AES Enterprise .
( record->security == WICED_SECURITY_WPA_MIXED_ENT    ) ? "WPA Mixed Enterprise" :
  ( record->security == WICED_SECURITY_WPA2_TKIP_ENT    ) ? "WPA2 TKIP  Enterprise" :
  ( record->security == WICED_SECURITY_WPA2_AES_ENT     ) ? "WPA2 AES   Enterprise" :
  ( record->security == WICED_SECURITY_WPA2_MIXED_ENT   ) ? "WPA2 Mixed Enterprise" :
FYI, I tested on sdk-6.4.
So you can check print_scan_result() function.
You can run scan snip code on sdk-6.4 to confirm this issue.
sure, will have a try.
Hello:
