sam4s i2c driver 1 byte read error fix
DaBa_2244756
25 likes received 10 likes received 10 likes given
platform_result_t platform_i2c_transfer( const platform_i2c_t* i2c, const platform_i2c_config_t* config, platform_i2c_message_t* messages, uint16_t number_of_messages )
    platform_result_t       result   =  PLATFORM_SUCCESS;
    Twi*                    twi      = ( Twi* )( i2c_runtime_data[i2c->i2c_block_id].peripheral->peripheral );
    platform_i2c_message_t* message_pointer;
    int i;
    int retry_count;
    /* Check input arguments */
    wiced_assert("Bad argument", (i2c != NULL) && ( config != NULL ) &&( messages != NULL ) && ( number_of_messages != 0 ));
    for ( i = 0; ( i < number_of_messages ) && ( result == PLATFORM_SUCCESS ); i++ )
        message_pointer = &messages;
        wiced_assert("Message pointer shouldn't be null", message_pointer != NULL);
        for ( retry_count = 0; retry_count < message_pointer->retries; retry_count++ )
            i2c_runtime_data[i2c->i2c_block_id].current_message = message_pointer;
            i2c_runtime_data[i2c->i2c_block_id].data_count      = 0;
            i2c_runtime_data[i2c->i2c_block_id].transfer_status = 0;
            /* Make sure all interrupts are disables at start */
            twi->TWI_IDR = ~0UL;
            if ( message_pointer->rx_buffer != NULL )
                /* Initiate an RX transfer */
                /* Set read mode and slave address */
                twi->TWI_MMR = 0;
                twi->TWI_MMR = TWI_MMR_MREAD | TWI_MMR_DADR(config->address);
                /* Enable NACK, RXRDY interrupts */
                twi->TWI_IER = TWI_IER_NACK | TWI_IER_RXRDY;
                if ( message_pointer->rx_length == 1 )
                    /* There is only byte to process, go straight to transfer complete
                     * interrupt, and process the last byte there */
                    twi->TWI_IDR = TWI_IDR_RXRDY;
                    twi->TWI_CR = TWI_CR_STOP | TWI_CR_START;//darius need place her, before  twi->TWI_IER = TWI_IER_TXCOMP;
                    /* Extract from sam4s user manual.
                     * When a single data byte read is performed, with or without internal address (IADR),
                     * the START and STOP bits must be set at the same time */
                    //twi->TWI_CR = TWI_CR_STOP | TWI_CR_START;//darius error her moved up
                else
                    /* Only required for receive to reset TXCOMP state */
                    twi->TWI_CR = TWI_CR_START;
