my os is windows10 and develope environment is WICED Studio 4.1.1 IDE.
my board is BCM43907(CYW43907).
I want to use load cell on BCM43907(CYW43907). board.
First, I bought the product.
(Hx711 breakout board : https://www.sparkfun.com/products/13879
Load senseor Combinator : https://www.sparkfun.com/products/13878
Load cell : https://www.sparkfun.com/products/10245 )
Second,
I checked the normal operation of the load cell through the "redbear duo" board (IDE: arduino).
(refer to "SparkFun_HX711_test.zip (arduino code)" and "hx711.zip(library)" )
Finally, After properly connecting the pins (GPIO x2, GND, VDD3v3) and writing the library and code(using arduino code,library) , I tested it with the BCM43907 board, but there was a problem with the output of the value.(refer to "load_cell_test.zip ( wiced studio code ) " )
The weight value is not stable.
Is there a difference between the behavior of arduino code and the behavior of wiced studio code?
Please help me figure out what's wrong.
(left : arduino IDE output right : wiced studio output)
GPIO
As the 43907 is not yet a broad market device and supported here on the IoT Community, please work with the local/regional Cypress sales team that enabled you with this product to setup the appropriate factory support.
