Hi Everyone!
I Really want to debug my program.
I Push the green bug Icon.  I can see the Next message
I use WICED-SDK 3.5.4
I Also Update all program (Check for update at help menu)
and Setting is below   like  create debugg process
Hi unirobotics,
Please don't use default gdb command("tools/ARM_GNU/bin/Win32/arm-none-eabi-gdb.exe") in "Debugger" tab. Instead, press "Browse.." and then select gdb debugger in tools folder like as "./WICED-SDK/tools/ARM_GNU/bin/Win32/arm-none-eabi-gdb.exe".
When I tested this, it worked fine.
Sung-Mok
SeyhanA_31
What is your host OS that you are running the WICED SDK in?
Depending on the host OS you need to change to the correct gdb executable.
Pick one of the following that matches to your host development OS.
Seyhan
Thank you! seyhan
I understand that it depending on OS.
But I use the windows 64 bit.  but there are no win64 directory. so. How to do it?
most people maybe use windows 64 bit.
Thank you!
The win32 binaries should run on win64
We don't provide native 64-bit tools since they aren't essential
the GDB should run correctly on win64
Are you able to run it from a windows command line?
Hi unirobotics,
Sung-Mok
