user_2212361
First like received First like given Welcome!
Hi
I have been testing the ofa. (WICED OTA Upgrade and Factory Reset (SDK 3.1.2) )
Connected to the otp web server, and the file was opened.
\WICED-SDK-3.3.1\WICED-SDK\build\demo_temp_control-MurataTypeYD\binary\demo_temp_control-MurataTypeYD.stripped.elf
proceeded to "start upgrade".
Receiving the data properly and then came the reboot messages.
But is not a reboot. Press the reset key, but this should not work.
Why does this happen?
Download ota_fr again and had access to a web server. And I've tried downloading progress.
The error occurred in the source below.
wiced_ota_server.c
static int process_upgrade_chunk( ota_http_request_message_t* request, wiced_tcp_stream_t* stream, void* arg )
if (wiced_framework_app_set_size( &app, file_size) != WICED_SUCCESS)
       printf("wiced_framework_app_set_size err - file_size:%d  \r\n", file_size );
       return -1;
Download ota_fa again and tried to upgrade, but the same error occurs.
What is the reason?
SDK : 3.3.1
serial flash : winbond w25q32bv
Are you trying to use OTA update from SDK 3.3.1 to update application built with SDK 3.3.1?
This should work and has been tested extensively
If you are getting error in that function - can you check the return value?
Hi.
Thank you for having answered.
=>  It is not well understood what you said.
       I have been testing a variety of sample code in the SDK 3.3.1.
=>    wiced_result_t result;
        if (wiced_framework_app_open( DCT_APP0_INDEX, &app ) != WICED_SUCCESS)
            printf("wiced_framework_app_open err  \r\n");
            return -1;
        printf("wiced_framework_app_open - app_id:%d, offset:%d, last_erased_sector:%d   \r\n",
                                       app.app_id, app.offset, app.last_erased_sector );
        if (wiced_framework_app_get_size( &app, &current_size ) != WICED_SUCCESS)
            printf("wiced_framework_app_get_size err  \r\n");
            return -1;
        printf("wiced_framework_app_get_size - current_size:%d  \r\n", current_size );
        result = wiced_framework_app_set_size( &app, file_size);
        if ( result != WICED_SUCCESS)
             printf("wiced_framework_app_set_size err[%d] - file_size:%d  \r\n", result, file_size );
            return -1;
Serial messages is shown below. error number : 4
wiced_framework_app_open - app_id:5, offset:0, last_erased_sector:-1
wiced_framework_app_get_size - current_size:0
wiced_framework_app_set_size err[4] - file_size:527152
Hi
serial flash replaced and tftp tested.
[TFTP]RRQ
current size 1080156160, request:0
new size 940888064
Writing size 512 from offset 0 [0x7f]
Writing size 512 from offset 512 [0x0]
Writing size 512 from offset 1024 [0x0]
Writing size 512 from offset 1536 [0x0]
Writing size 512 from offset 2048 [0x0]
Writing size 512 from offset 2560 [0x0]
Writing size 512 from offset 3072 [0x0]
Writing size 512 from offset 3584 [0x0]
Writing size 512 from offset 4096 [0x0]
Writing size 512 from offset 4608 [0x0]
Error Writing, err:4
Writing size 512 from offset 5120 [0x0]
Writing size 512 from offset 5632 [0x0]
Writing size 512 from offset 6144 [0x0]
Writing size 512 from offset 6656 [0x0]
Writing size 512 from offset 7168 [0x0]
Writing size 512 from offset 7680 [0x0]
Writing size 512 from offset 8192 [0x0]
After downloading the tftp tested again.
current size 0, request:0
Error wiced_framework_app_set_size, err:4, size:527152
Please advise why this is the result comes out.
Is this error on the Winbond SFLASH?
SFLASH use W25Q32BV / Winbond.
error message is shown in the tftp sample code.
tftp.c
wiced_result_t snip_tftp_establish( tftp_t* tftp, void* p_user )
    uint32_t file_size = tftp->transfer_size;
    uint8_t file_index = get_file_index( tftp->filename );
    if ( file_index == (uint8_t) -1 )
        return WICED_ERROR;
    if ( wiced_framework_app_open( file_index, &app ) != WICED_SUCCESS )
        return WICED_ERROR;
    if ( wiced_framework_app_get_size( &app, &current_size ) != WICED_SUCCESS )
        return WICED_ERROR;
   printf( "current size %lu, request:%d \n", current_size, tftp->request );
    if ( tftp->request == TFTP_GET )
        result = wiced_framework_app_set_size( &app, file_size );
        if ( result != WICED_SUCCESS )
            printf( "Error wiced_framework_app_set_size, err:%d, size:%d \n", result, file_size );
            return WICED_ERROR;
        result = wiced_framework_app_get_size( &app, &current_size );
            printf( "Error wiced_framework_app_get_size, err:%d \n", result );
            return WICED_ERROR;
    else
        if ( current_size == 0 )
            return WICED_ERROR;
    offset = 0;
   printf( "new size %lu\n", current_size );
    return WICED_SUCCESS;
wiced_result_t snip_tftp_write( tftp_t* tftp, uint8_t* data, void* p_user )
    printf( "Writing size %d from offset %lu [0x%x] \r\n", tftp->block_size, offset, data[ 0 ] );
    wiced_result_t result = wiced_framework_app_write_chunk( &app, data, tftp->block_size );
        printf( "Error Writing, err:%d \n", result );
    offset += tftp->block_size;
I have same issue .
So, I need this issue solution.
This issue is not resolved?
Can you please try a newer SDK?
I'm used SDK version is 3.3.1
3.5.2 SDK is error fixed?
I am not sure, but this error on 3.3.1 has not been reported by any other customer. Hence would suggest to see if you can try 3.5.2 first
I,m used SSBWMN01 borad check.
USI BM30 board is normal operation
but, SSBWMN01 board error operation.
Then please work with SPIL and Exceltech to make sure there is no HW issue here on their board
SPIL platform file support (SSBWMN01.mk) apply.
And, snip.tftp app is normal operation.
but, i'm make apps apply tftp routine.
ota issue is same.
It added more questions to below test sequence result different.
1. snip.tftp download download_apps run -> tftp download my test app-> normal behavour
-> reboot run my app-> tftp download -> normal behavour
2. my app download download_apps run -> tftp download -> error and not update
error offset is always 4608.
First ota/tftp app download -> my apps dowload(ota/tftp) -> my app run -> ota/tfpt run is normal behavour.
But, my app download-> ota/tftp run is error.
I would like to know how to look at any part.
