ofexc_2213241
We like to run and debug the snip.apple_homekit.window_covering_service on a BCM9WCD9EVAL1 Board.
But as far the debugger is started, the openocd-all-bcrm-libftdi.exe crashes with the message "funktioniert nicht mehr".
We have the following configuration:
WICED-Studio-5.0.1.9 on WIN7
Eval Board: BCM9WCD9EVAL1 with BCM943364WCD1_2 mounted.
We inserted the Platform BCM943364WCD1 in VALID_PLATFORMS in window_covering_service.mk file and made the following target:
snip.apple_homekit.window_covering_service-BCM943364WCD1-debug download USE_MFI=1
After the debugger has been started, it crashes. See attached openocd log.
Whats's wrong here?
PS:
The download and run configuration for this target (snip.apple_homekit.window_covering_service-BCM943364WCD1 download run USE_MFI=1)
is runnig without any problem.
The debugging for the demo.aws_iot.pub_sub.publisher works also.
GauravS_31
250 solutions authored 250 sign-ins First comment on KBA
Go to the debug configuration settings-> Startup tab and remove stepi under Run Commands window and check if this solves your problem.
GauravS_31
