Wi-Fi Combo Forum Discussions
user_2212361
First like received First like given Welcome!
Hi.
I want to check if the firmware download is good .
So I found the openOCD command 'verify_image'.
I tested each bootloader, DCT, and Application image.
The result is a bootloader, and the application image is normal.
But DCT is not normal.
Can not see the DCT image?
AjayB_76
100 sign-ins 10 questions asked 5 questions asked
Hi 안진호
Can you let us know the platform in which you are seeing this issue? Also specify the version of WICED in which the image was compiled.
Ajay
