mbedTLS
sanees
10 sign-ins 5 sign-ins First reply posted
We have used Wiced SDK for Type 1LD development. Wiced doesn't supports LWM2M protocol. We are trying to port an open source LWM2M implementation like Wakaama/Anjay to Wiced SDK. But it seems like the mbedtls module available with Wiced /type 1ld have been tweaked at many places (compared to open source version). This creates a lot of issues in the UDP/TCP layer. We know that Wiced /type 1ld uses mbedtls to support many built in modules (like WiFi). Hence it is not possible to tweak or replace the Wiced /type 1ld mbedtls version. At this point, we think that it might not be possible to port an open source LWM2M implementation to Wiced SDK.
Rakesh_BG
50 solutions authored 100 replies posted 100 sign-ins
Hi ,
Modus tool box doesn't support murata type1LD for now. You can use wiced only for murata type1LD.
Rakesh B G
sanees
If there is any way to move forward ,pls let us know . Any sample code that demonstrates working mbedTLS with an application using wiced will be very helpful. I also tried for pin compatible part of murata type 1LD without any luck that may support newer tools and lwm2m.
Rakesh_BG
Hi @sanees ,
There is no support for lwm2m in wiced. Actually, wiced is Not recommended for new designs .
Rakesh B G
Understood, there is no support for LWM2M in wiced, but type1LD murata board has only support in WICED.
Does you new MODUS tool support murata type1LD or for that matter does any other tool set support Murata Type 1LD?
Rakesh_BG
Hi ,
Rakesh B G
