I can only run UDP with iperf and LWIP in SDK 6.2.1. If i attempt to run TCP mode, the system crashes with an assert in the network stack:
CYW43907
Function: low_level_output
Line: 202
Thread: tcpip_thread
LWIP_ASSERT( "No chained buffers", ( ( p->next == NULL ) && ( ( p->tot_len == p->len ) ) ) );
Any ideas for a fix to allow TCP and lwip?
With UDP, the transmit buffer is limited to 4.28KB which appears to negatively impact the throuhhput result but I cannot change it with the -w arugment so i guess it is based on a LWIP configuration? Anyone know where to change this?
TCPIP
WICED Studio
Per #1, the console test app in 6.2.1 works with TCP. Strange that it works here and not in my application, both are running FreeRTOS and LWIP.
Per #2, in the console app, the UDP buffer size is 14.3 KBytes so this seems like defines in the console makefile setup this.
Higher UDP throughput is working by pulling some defines from the console makefile for the CYW43907
GLOBAL_DEFINES += TX_PACKET_POOL_SIZE=40 \
RX_PACKET_POOL_SIZE=40 \
WICED_TCP_TX_DEPTH_QUEUE=32 \
WICED_ETHERNET_DESCNUM_TX=32 \
WICED_ETHERNET_DESCNUM_RX=8 \
WICED_ETHERNET_RX_PACKET_POOL_SIZE=40+WICED_ETHERNET_DESCNUM_RX \
WICED_TCP_WINDOW_SIZE=32768
TCP with IPERF is still failing on my end. I have asserts enabled to catch fatal errors in the network stack but maybe the no chained buffer assert is not fatal
I checked the test.console example in SDK 6.2.1 with FreeRTOS/LwIP combination. I don't seem to hit any asserts with tcp with iperf.
Platform CYW943907AEVAL1F initialised
Started FreeRTOS v9.0.0
WICED_core Initialized
Initialising LwIP v2.0.3
DHCP CLIENT hostname WICED IP
WWD SoC.43909 interface initializing with US/0
WLAN MAC Address : A4:08:EA:D9:D4:E6
WLAN Firmware : wl0: Feb 26 2019 18:16:13 version 7.15.168.126 (r711020) FWID 01-bc2dab52
WLAN CLM : API: 12.2 Data: 9.10.74 Compiler: 1.31.3 ClmImport: 1.36.3 Creation: 2019-02-26 18:10:19
Console app
> iperf -v
iperf version 2.1.0 (20 Feb 2012) single threaded
> join CY-IOT-HOTSPOT wpa2 12345678
Joining : CY-IOT-HOTSPOT
Successfully joined : CY-IOT-HOTSPOT
Setting IPv6 link-local address
Obtaining IPv4 address via DHCP
Waiting for IPv6 address validation
IPv6 Network ready IP: FE80::A608:EAFF:FED9:D4E6
IPv4 Network ready IP: 10.40.2.18
> iperf -c 10.40.2.166
Client connecting to 10.40.2.166, TCP port 5001
TCP window size: 35.6 KByte (default)
[ ID] Interval Transfer Bandwidth
[ 0] 0.0-10.0 sec 11.2 MBytes 9.38 Mbits/sec
Could you please provide a stripped down version of your application so that we can reproduce this on our end?
To increase the throughput; i.e window size tunables are located in console.mk for iperf as you have already found out.
Thanks for the feedback.
Did you run the project in a debug build? Typically the asserts are disabled in normal builds but enabled in debug. In my application i have enabled asserts in normal builds so they can be logged and then reset the processor.
I checked it in the debug build only hoping to see the assert. Is there anything else that you think might be differing in our setups (or some piece of assert enabled etc)?
- Platform CYW943907AEVAL1F initialised
- Started FreeRTOS v9.0.0
- WICED_core Initialized
- Initialising LwIP v2.0.3
- DHCP CLIENT hostname WICED IP
- WWD SoC.43909 interface initializing with US/0
- WLAN MAC Address : A4:08:EA:D9:D4:E6
- WLAN Firmware : wl0: Feb 26 2019 18:16:13 version 7.15.168.126 (r711020) FWID 01-bc2dab52
- WLAN CLM : API: 12.2 Data: 9.10.74 Compiler: 1.31.3 ClmImport: 1.36.3 Creation: 2019-02-26 18:10:19
The WLAN firmwaree shows you tested a newer sdk version rather than sdk-6.2.1.
Good catch axel.lin_1746341
RaktimR_11, are you testing with 6.2.1 or the latest internal branch that will become the SDK (6.4)?
I am testing in SDK 6.2.1. Please check the log below but I am not seeing any asserts. The firmware/ blob file was different in the earlier log. Thanks for pointing that out.
Starting WICED vWiced_006.002.001.0013
WLAN Firmware : wl0: May 15 2018 19:39:17 version 7.15.168.114 (r689934) FWID 01-d6f88905
WLAN CLM : API: 12.2 Data: 9.10.74 Compiler: 1.31.3 ClmImport: 1.36.3 Creation: 2018-05-15 19:33:15
Init took ~449 ms
Console app
> wl ver
7.16 RC99.19
> join CY-IOT-HOTSPOT wpa2 10t12356b1
IPv4 Network ready IP: 10.40.2.180
> iperf -c 10.40.2.164
Client connecting to 10.40.2.164, TCP port 5001
TCP window size: 24.6 KByte (default)
[ 0] 0.0-10.0 sec 1.33 MBytes 1.11 Mbits/sec
- Starting WICED vWiced_006.002.001.0013
Starting WICED vWiced_006.002.001.0013 Platform CYW943907AEVAL1F initialised Started FreeRTOS v9.0.0 Initialising LwIP v2.0.3 DHCP CLIENT hostname WICED IP WWD SoC.43909 interface initializing with US/0 WLAN MAC Address : A4:08:EA:D9:D4:E6 WLAN Firmware : wl0: May 15 2018 19:39:17 version 7.15.168.114 (r689934) FWID 01-d6f88905 WLAN CLM : API: 12.2 Data: 9.10.74 Compiler: 1.31.3 ClmImport: 1.36.3 Creation: 2018-05-15 19:33:15 Init took ~449 ms Console app > wl ver 7.16 RC99.19 wl0: May 15 2018 19:39:17 version 7.15.168.114 (r689934) FWID 01-d6f88905 > > > > > join CY-IOT-HOTSPOT wpa2 10tl@b123 Joining : CY-IOT-HOTSPOT Successfully joined : CY-IOT-HOTSPOT Setting IPv6 link-local address Obtaining IPv4 address via DHCP Waiting for IPv6 address validation IPv6 Network ready IP: FE80::A608:EAFF:FED9:D4E6 IPv4 Network ready IP: 10.40.2.180 > > > iperf -c 10.40.2.164 ------------------------------------------------------------ Client connecting to 10.40.2.164, TCP port 5001 TCP window size: 24.6 KByte (default) ------------------------------------------------------------ [ ID] Interval Transfer Bandwidth [ 0] 0.0-10.0 sec 1.33 MBytes 1.11 Mbits/sec
Your SDK 6.2.1 (vWiced_006.002.001.0013) is different from the public download sdk-6.2.1 (vWiced_006.002.001.0002).
Anyway, I just want to point out that you had better use the same sdk to reproduce the user reported issue.
BTW, I remember that I observed the same assert.
I have the same problem, after analysis, I concluded that WICED SDK 6.4 with LWIP/FreeRTOS for CYW43907 is not finished yet, wish Cypress will make LWIP/FreeRTOS for CYW43907 ready as soon as possible.
LwIP uses chained pbuf when sending TCP packets, but WWD is not support yet:
1. in WICED/platform/MCU/BCM4390x/peripherals/shared/m2m_hnddma.c, function m2m_dma_txfast is the last function which will send packet to wifi MCU, the code that support chained buffers is commented, it will only send the first packet of the buffer chain, if ignore LWIP_ASSERT( "No chained buffers", ( ( p->next == NULL ) && ( ( p->tot_len == p->len ) ) ) ) in low_level_output/wwd_network.c, data will not send correctly.
2. in WICED/WWD/internal/wwd_sdpcm.c, some code in wwd_sdpcm_send_common also implied this( SUPPORT_BUFFER_CHAINING was not defined):
