Just doing "iperf --help" makes the iperf app throw a hardware exception. I have modified the iperf.mk to have less buffers. the particular STM processor I use has 756K Flash and 96K Ram. iperf that is on WICED-SDK-2.2.1 works on the same hardware. Is there anything changed from SDK2.2.1 to SDK2.3.1 related to the iperf app? Does anyone have the similar issue???
SPI
I discovered that the STM32F1xx platform does not compile CPP files correctly which was causing the fault you are seeing.
Attached is a new copy of the STM32F1xx.mk file that can be found at:
WICED-SDK\Wiced\Platform\common\ARM_Cortex_M3\STM32F1xx
Please replace your copy with the one attached, run "make clean" and then rebuild the iperf application.
