mili_2550941
     We use BCM43353 as WIFI+BT solution. Can we use SDIO v3.0 port transceive WIFI data & BT AUDIO data(not use PCM or I2S port)?
Thanks!
VinayakS_26
Are you asking for a shared SDIO bus for WiFi data & BT audio? Why is this required?
Keeping a shared SDIO bus would affect the Throughput of WiFi. There would significant wastage of bandwidth of SDIO considering bluetooth data rates are limited to just around 20Mbps. Besides currently, there is no driver support for BT through SDIO.
-Thanks
Vinayak
VinayakS_26
-Thanks
Vinayak
Dear Vinayak:
     Thanks for your answer.
     We want shared SDIO for wifi data & BT AUDIO to decrease connection.
     As your suggestion,we will not choice this solution to ensure  the SDIO bus throughput.
Thanks!
minli
