i'm try to design PCB based on CYW54907.. but how can i design it without any recommended footprint dimension of chip CYW54907..
i checked datasheet but there does not mentioned clear dimensions about PAD Ball spacing and all..
can you help me pls.
thank you
jingesh narola
As chip down designs for WiFi/Combo are not supported within the broad market and here on the community, you will want to work with your local Cypress/Distribution Sales team to qualify the engagement and arrange direct factory or design partner support through a partner.
