product that we make is for united state market.
we need under spec.
1. we want to use 1~13 ch.
2. we want to use each mode(b/g/n)
if WICED_COUNTRY_UNITED_STATES is configured then 12, 13 ch can not use
if WICED_COUNTRY_KOREA_REPUBLIC_OF is configured then A connection to a 802.11n-only AP can not be established.
Depending on the country code changes, what is change?
Does anyone have an explanation for the behaviour?
I think that regardless of changing country code, wifi module must establish 802.11n-only ap
I have one more question
*data = (uint32_t) GMODE_PERFORMANCE;
retval = wwd_sdpcm_send_ioctl( SDPCM_SET, WLC_SET_GMODE, buffer, 0, WWD_STA_INTERFACE );
after applying upper code, i checked "probe request" packet
but this code dosent apply packet.
and if GMODE_B_DEFERRED, GMODE_ONLY is configured, wifi can not work
thanks
FYI,
There is a issue about setting country code to WICED_COUNTRY_KOREA_REPUBLIC_OF
on sdk-3.5.2. (Thought it's reported on a different platform, might be related.)
