when we post different msgs to the server, the server will return different json data. I studied the example application ‘httpbin_org',  only one function 'parse_http_response_info()' was registered to parse all json data. I want add another function to parse different json data returned by the server.
how can I do it? please kindly help, thanks.
GauravS_31
10 questions asked 250 solutions authored 250 sign-ins
You can register another callback function and then call the function wiced_JSON_parser() to parse another parameter within the same JSON object. For instance in the snip httpbin_org, the callback parse_http_response_info() had been registered to parse the "url". You can register another callback parse_http_response_info2() to parse "Host" before calling wiced_JSON_parser().
GauravS_31
Dear grsr
     Thank you so much for your help, it works perfectly according to your reply. By the way, I want to konw how to add another JSON object too, please take a look at this at your convenience.
      Thank you!
