I set up my target ssid and password in the DCT then called wiced_network_up. Since my target ssid won't be up 100% during my application. I saw the wiced_network_up tried to join the target ssid three times and then declared the "failed to join : target ssid"
I would like to have it keep try to connect to the ssid, instead of stooping after only 3 tries. How could I achieve this?
In other API I used before, I can set the something like wifi,config,auto_connection to true. then the wifi API will keep trying to connect to the ssid provided. Is there anything similar in wiced?
Wifi+Bluetooth
- wifi command
Use a while loop to keep calling wiced_network_up() until it returns success.
