Wi-Fi Combo Forum Discussions
BaGo_4138971
Hi All,
I trying to send some data over UART but wiced send generating exception condition.
How to check and debug exception .
Basavanagouda.
GauravS_31
250 solutions authored 250 sign-ins First comment on KBA
If we understood correctly, your WICED device UART is sending data bytes. The IFSR is set when there is a debug exception generated due to breakpoint. The IFSR=2 indicates debug event fault. Do you observe this issue in debug or run mode? Can you disable flow control and reduce the number of bytes transmitted?
GauravS_31
