OmEs_4437866
First like given
Please guide me in this issue, I want to add a global configuration file which is preincluded in every file.
Hello:
i didn't find an accurate global position for your question, but you can add below setting in your .mk file by referring below example.
ifneq ($(wildcard $(CURDIR)trace/$(RTOS)_trace.h),)
# Make sure to include this trace_macros.h first (to ensure the trace macros are defined accordingly)
GLOBAL_CFLAGS   += -include $(CURDIR)trace/$(RTOS)_trace.h
GLOBAL_CXXFLAGS += -include $(CURDIR)trace/$(RTOS)_trace.h
Zhengbao_Zhang
250 sign-ins First comment on KBA 10 questions asked
hello:
if you are using 43xx module,  we have a include directory   \43xxx_Wi-Fi\include
you can put your global define head file here.
I am sorry my question was not to the point. I want a global configuration header file to be automatically included in each and every file in the project. In other words, I need to add global defines but rather than listing them in a makefile I would rather write them in a master config header file.
Sorry, I still can't understand the meaning,  we have global header file in the include directory , if you want to use the defines in the .h file, you need to include it, I do not know the file you are describing now.
Yes I understand, I want the compiler to include this global file within the compiler flags. I do not want to go and include this file in every source file in the project. I want the compiler to do this for me. There is a "-include" compiler option in gcc I want to use it but dont know where to add it in your makefiles.
Hello:
Thank you for your time.
