if I use one BCM43909 as the software AP, others BCM43909 as the guest terminal, how many guest terminals BCM43909 can link one BCM43909 AP and work well ?  thanks!  kuka
AxLi_1746341
Level 7
Level 7
10 comments on KBA 5 comments on KBA First comment on KBA
This looks like a generic question to me:
The number of client to associate the AP is limited by:
1) Return value of wwd_wifi_get_max_associations()
2) system memory
(unless your device has a lot memory) in most case it's likely the limitation is the system memory.
This depends on how much memory is already taken by your application running the AP.
You had better test it on a real hardware to get the answer.
MichaelF_56
Unfortunately, the BCM43909 has yet to be released to the broad market, so it is not supported here on the community. Please work through one of your regional franchised Distributors​ to obtain support for this device.
mingwei
AxLi_1746341
Level 7
Level 7
2) system memory
OK, many thanks for your great support !
BEST REGARDS
Kuka Huang
