Sep 09, 2019
08:48 AM
Sep 09, 2019
08:48 AM
Hello,how can I activate MCS8. When trying the command: 5g_rate -h 8 ,I am getting this error: remote cdc header return error code (-29).
if I set the similar command for VHT : 5g_rate -v 0 -s 2
Device used: CYW954907AEVAL1F
Ana
02:43 AM
Sep 11, 2019
02:43 AM
CYW54907 supports single spatial stream; i.e NSS = 1 as mentioned by the datasheet. That's why when you try to use NSS=2, it throws up an error.
