i have a customer working with the 43907 part (using imp005 module) with a PRoC module.
are there any written details/spec of the 43907 External Coexistence Interface so the PRoC can have control?
Basic on/off will do for development work. but i couldn't find any examples.
Since the 43907 is not yet supported within the broad market and here on the community, you will want to use our internal case management system as opposed to the community.
as in mycases on cypress.com or is there another case system for IOT parts?
Graham
Correct. IoT uses the same internal case system.
perfect, thanks will load there now.
