Wi-Fi Combo Forum Discussions
12:01:12 **** Build of configuration Default for project WICED-SDK ****
"E:\\WICED_WIFI_3_7_0\\WICED-SDK-3.7.0\\WICED-SDK\\make.exe" snip.ota_fr-BCMUSI22 download download_apps
MAKEFILE MAKECMDGOALS=snip.ota_fr-BCMUSI22 download download_apps OTA2_SUPPORT is disabled
Making config file for first time
| IMPORTANT NOTES        |
| Wi-Fi MAC Address        |
|    The target Wi-Fi MAC address is defined in <WICED-SDK>/generated_mac_address.txt                 |
|    Ensure each target device has a unique address.                                                  |
| MCU & Wi-Fi Power Save        |
|    It is *critical* that applications using WICED Powersave API functions connect an accurate 32kHz |
|    reference clock to the sleep clock input pin of the WLAN chip. Please read the WICED Powersave   |
|    Application Note located in the documentation directory if you plan to use powersave features.   |
Building Bootloader
Building Serial Flash Loader App
MAKEFILE MAKECMDGOALS=waf.sflash_write-NoOS-BCMUSI22-SDIO OTA2_SUPPORT is disabled
| IMPORTANT NOTES        |
| Wi-Fi MAC Address        |
WICED/platform/MCU/STM32F4xx/peripherals/platform_watchdog.c:55:0: warning: "DBG_WATCHDOG_TIMEOUT_MULTIPLIER" redefined
     #define DBG_WATCHDOG_TIMEOUT_MULTIPLIER    (3600)
In file included from ././WICED/platform/MCU/STM32F4xx/../platform_stdio.h:11:0,
                 from WICED/platform/MCU/STM32F4xx/peripherals/platform_watchdog.c:30:
./platforms/BCMUSI22/./platform_config.h:29:0: note: this is the location of the previous definition
#define DBG_WATCHDOG_TIMEOUT_MULTIPLIER ( 1875 )
Compiling App_SFlash_write
Compiling Platform_BCMUSI22
Compiling WICED
Compiling WWD_NoOS_Interface
Compiling Lib_SPI_Flash_Library_BCMUSI22
Compiling Lib_GPIO_button
Finished Building Bootloader
Compiling Lib_Wiced_RO_FS
Processing resources
Creating security credentials
Compiling STM32F4xx
Making DCT image
Compiling common_GCC
Compiling STM32F4xx_Peripheral_Drivers
Compiling Lib_Ring_Buffer
Compiling Lib_crc
Compiling STM32F4xx_Peripheral_Libraries
Making build/waf.sflash_write-NoOS-BCMUSI22-SDIO/libraries/App_SFlash_write.a
Making build/waf.sflash_write-NoOS-BCMUSI22-SDIO/libraries/Platform_BCMUSI22.a
Making build/waf.sflash_write-NoOS-BCMUSI22-SDIO/libraries/WICED.a
Making build/waf.sflash_write-NoOS-BCMUSI22-SDIO/libraries/WWD_NoOS_Interface.a
Making build/waf.sflash_write-NoOS-BCMUSI22-SDIO/libraries/Lib_SPI_Flash_Library_BCMUSI22.a
Making build/waf.sflash_write-NoOS-BCMUSI22-SDIO/libraries/Lib_GPIO_button.a
Making build/waf.sflash_write-NoOS-BCMUSI22-SDIO/libraries/Lib_Wiced_RO_FS.a
Making build/waf.sflash_write-NoOS-BCMUSI22-SDIO/libraries/STM32F4xx.a
Making build/waf.sflash_write-NoOS-BCMUSI22-SDIO/libraries/common_GCC.a
Making build/waf.sflash_write-NoOS-BCMUSI22-SDIO/libraries/STM32F4xx_Peripheral_Drivers.a
Making build/waf.sflash_write-NoOS-BCMUSI22-SDIO/libraries/Lib_Ring_Buffer.a
Making build/waf.sflash_write-NoOS-BCMUSI22-SDIO/libraries/Lib_crc.a
Making build/waf.sflash_write-NoOS-BCMUSI22-SDIO/libraries/STM32F4xx_Peripheral_Libraries.a
Making waf.sflash_write-NoOS-BCMUSI22-SDIO.elf
Making waf.sflash_write-NoOS-BCMUSI22-SDIO.bin
                                  |         |  Static |
              Module              |  Flash  |   RAM   |
App                               |       0 |   21126 |
Host MCU-family library           |       0 |   11340 |
Interrupt Vectors                 |       0 |     388 |
libc                              |       0 |     548 |
platform                          |       0 |    1156 |
Ring_Buffer                       |       0 |      40 |
SPI_Flash_Library_BCMUSI22        |       0 |     908 |
Startup Stack & Link Script fill  |       0 |     486 |
WWD                               |       0 |     176 |
TOTAL (bytes)                     |       0 |   36168 |
Build complete
Finished Building Serial Flash Loader App
Compiling App_OTA_fr_run
Compiling WICED
Compiling Lib_OTA_Server
Compiling WWD_ThreadX_Interface
Compiling WICED_ThreadX_Interface
Compiling WWD_for_SDIO_ThreadX
Compiling Supplicant_BESL
Compiling Lib_DNS
Compiling NetX_Duo
Compiling STM32F4xx
Compiling Lib_TLV
Compiling Lib_base64
Compiling Lib_Linked_List
Compiling Lib_crypto_open
Compiling Lib_micro_ecc
Compiling WWD_NetX_Duo_Interface
Compiling WICED_NetX_Duo_Interface
Compiling Lib_crc
Compiling Lib_DHCP_Server
Making build/snip.ota_fr-BCMUSI22/libraries/App_OTA_fr_run.a
Making build/snip.ota_fr-BCMUSI22/libraries/Platform_BCMUSI22.a
Making build/snip.ota_fr-BCMUSI22/libraries/WICED.a
Making build/snip.ota_fr-BCMUSI22/libraries/Lib_OTA_Server.a
Making build/snip.ota_fr-BCMUSI22/libraries/Lib_SPI_Flash_Library_BCMUSI22.a
Making build/snip.ota_fr-BCMUSI22/libraries/Lib_GPIO_button.a
Making build/snip.ota_fr-BCMUSI22/libraries/WWD_ThreadX_Interface.a
Making build/snip.ota_fr-BCMUSI22/libraries/WICED_ThreadX_Interface.a
Making build/snip.ota_fr-BCMUSI22/libraries/WWD_for_SDIO_ThreadX.a
Making build/snip.ota_fr-BCMUSI22/libraries/Supplicant_BESL.a
Making build/snip.ota_fr-BCMUSI22/libraries/Lib_DNS.a
Making build/snip.ota_fr-BCMUSI22/libraries/NetX_Duo.a
Making build/snip.ota_fr-BCMUSI22/libraries/Lib_Wiced_RO_FS.a
Making build/snip.ota_fr-BCMUSI22/libraries/STM32F4xx.a
Making build/snip.ota_fr-BCMUSI22/libraries/Lib_TLV.a
Making build/snip.ota_fr-BCMUSI22/libraries/Lib_base64.a
Making build/snip.ota_fr-BCMUSI22/libraries/Lib_Linked_List.a
Making build/snip.ota_fr-BCMUSI22/libraries/Lib_crypto_open.a
Making build/snip.ota_fr-BCMUSI22/libraries/Lib_micro_ecc.a
Making build/snip.ota_fr-BCMUSI22/libraries/WWD_NetX_Duo_Interface.a
Making build/snip.ota_fr-BCMUSI22/libraries/WICED_NetX_Duo_Interface.a
Making build/snip.ota_fr-BCMUSI22/libraries/common_GCC.a
Making build/snip.ota_fr-BCMUSI22/libraries/STM32F4xx_Peripheral_Drivers.a
Making build/snip.ota_fr-BCMUSI22/libraries/Lib_Ring_Buffer.a
Making build/snip.ota_fr-BCMUSI22/libraries/Lib_crc.a
Making build/snip.ota_fr-BCMUSI22/libraries/Lib_DHCP_Server.a
Making build/snip.ota_fr-BCMUSI22/libraries/STM32F4xx_Peripheral_Libraries.a
Making snip.ota_fr-BCMUSI22.elf
Making snip.ota_fr-BCMUSI22.bin
                                  |         |  Static |
App                               |     293 |       0 |
base64                            |     521 |       0 |
crc                               |    1060 |       0 |
crypto_open                       |   41125 |       1 |
DHCP_Server                       |    1476 |     132 |
DNS                               |      68 |      44 |
Host MCU-family library           |   14611 |    2481 |
Interrupt Vectors                 |     388 |       0 |
libc                              |   33826 |    3136 |
micro_ecc                         |    6212 |       0 |
Networking                        |    4880 |   13276 |
NetX-Duo - Interfaces & Stacks    |       0 |      16 |
OTA_Server                        |    8239 |     696 |
Other                             |   45436 |     535 |
Packet Buffers                    |       0 |   23086 |
platform                          |    1260 |     252 |
RAM Initialisation                |    2492 |       0 |
resources                         |      16 |       0 |
Ring_Buffer                       |     112 |       0 |
SPI_Flash_Library_BCMUSI22        |     856 |       0 |
Startup Stack & Link Script fill  |      54 |       7 |
Supplicant - BESL                 |   23355 |     615 |
ThreadX                           |    8596 |     396 |
Wi-Fi Firmware                    |  363808 |       0 |
WICED                             |    3445 |     960 |
WWD                               |   14679 |    3039 |
TOTAL (bytes)                     |  574316 |   48672 |
Downloading Bootloader ...
Building apps lookup table
Download complete
Downloading DCT ...
Download complete
Downloading Application ...
Download complete
Downloading FR_APP build/snip.ota_fr-BCMUSI22/binary/snip.ota_fr-BCMUSI22.stripped.elf at sector 1  address 4096...
make.exe[1]: *** [FR_APP_DOWNLOAD] Error 1
tools/makefiles/wiced_apps.mk:227: recipe for target 'FR_APP_DOWNLOAD' failed
make: *** [main_app] Error 2
Makefile:286: recipe for target 'main_app' failed
JoYi_1844281
Level 6
Level 6
100 sign-ins 100 replies posted 50 likes received
Does the ota_fr work on previous version SDK of same platform ?
I did not try it in prevouse version,but I checked with 3.7.0/3.5.2, same problem happen.
Do you have  install  external SPI flash on the EVB ?
ota_fr need the external SPI flash to work
yes, I already installed external flash on EVB.I know that.
The external SPI should install on U10 !
How many platform patch you apply on SDK?  And patch file name ?
Where you got it ?
yes already on U10 positon.
I applied 2 patches got from USI.
WM-BN-BM-22_SDK_3.5.2_platform_patch,
sdk3520_src_bm22_30_33-patch
You have to apply another patch for SPI interface !
jone
Thanks for all of your help.
which patch?please tell me.
