Wi-Fi Combo Forum Discussions
Is there any support for dot11MgmtOptionTimingMsmt?
If more precise timing is required than that available from NTP, what chipset(s) should be used?
What would the best time resolution be?
GregG_16
25 sign-ins 25 comments on KBA 10 comments on KBA
Is this still an issue for you?  It is outside what we typically discuss here, but if needed, I can find help to look into it.
Please send me a message.
Yes. I'm looking into which chipset that will enable precision timing - resolution of ~ 10 microseconds for keeping a network of sensors reporting data (millisecond scale) in sync.
