Hello, I have a CYW943907AEVAL1F board and I have an issue:
I'm testing the last version of SDK: 6.6.1.1 and with "test.console-CYW943907AEVAL1F download run" target. I'm testing with peap protocol.
And I have WWD_NOT_KEYED as result:
TLS handshake failed with error = [4]
Join result 1007:
Supplicant result = [6001]
And in the freeradius side I can see only a "Send Accept Challenge" but I dont get an "Send access acept".
1.- What things do I have to modified in order to test it with peap protocol?
2.- The first step in the user guide says that we need to configure the certificates, is it needed for peap? if yes, which one?
I already tried to replace WIFI_USER_CERTIFICATE_STRING with CA.pem and server.pem and it doesnt work.
3.- If it's needed a certificate, is there a way to avoid it in code?
4.- I saw a variable named eap_identity and I set to "testing" which is my user, is that correct? Or how can I set that variable?
Vanessa
ispn:38946:1:0
l1:314:1:0
Hello:
You can take a reference from the file :
WICED-Studio-6.6/43xxx_Wi-Fi/doc/WICED-Enterprise-Security-User-Guide.pdf
Hello:
