We are trying to set the band for AP entries in DCT but the stack seems to be ignoring them. It finds the network regardless of the band we tell it to look at, implying it is scanning both bands regardless of the setting.
We have a configuration file we use to populate an array:
wifi_list_size = 0;
cJSON_ArrayForEach(entry, entries)
cJSON *ssid = cJSON_GetObjectItemCaseSensitive(entry, "SSID");
cJSON *pw = cJSON_GetObjectItemCaseSensitive(entry, "PW");
cJSON *band = cJSON_GetObjectItemCaseSensitive(entry, "Band");
// Set SSID
strcpy(wifi_list[wifi_list_size].ssid, ssid->valuestring);
// Set Security
strcpy(wifi_list[wifi_list_size].password, pw->valuestring);
wifi_list[wifi_list_size].security = true;
// Set Band
if(strncmp("5GHz", band->valuestring, strlen("5GHz")) == 0)
wifi_list[wifi_list_size].band = WICED_802_11_BAND_5GHZ;
else if(strncmp("2.4GHz", band->valuestring, strlen("2.4GHz")) == 0)
wifi_list[wifi_list_size].band = WICED_802_11_BAND_2_4GHZ;
else
wifi_list[wifi_list_size].band = WIFI_DEFAULT_BAND;
// increment number of entries
wifi_list_size++;
Then we update the DCT using that array
// get the wi-fi config section for modifying, any memory allocation required would be done inside wiced_dct_read_lock()
wiced_dct_read_lock( (void**) &dct_wifi_config, WICED_TRUE, DCT_WIFI_CONFIG_SECTION, 0, sizeof( *dct_wifi_config ) );
// update top-level parameters
dct_wifi_config->country_code = GetWifiCountry();
// write the smaller of credentials in wifi.json and what's allowed by the platform
uint32_t wifiCount = (GetWifiListLength() < CONFIG_AP_LIST_SIZE) ? GetWifiListLength() : CONFIG_AP_LIST_SIZE;
for (uint32_t i=0; i<wifiCount; i++)
// get the entry from configuration
entry = GetWifiParameters(i);
// SSID
dct_wifi_config->stored_ap_list.details.SSID.length = strlen(entry->ssid);
strlcpy((char *)dct_wifi_config->stored_ap_list.details.SSID.value,
entry->ssid,
sizeof(dct_wifi_config->stored_ap_list.details.SSID.value));
// password
dct_wifi_config->stored_ap_list.security_key_length = strlen(entry->password);
strlcpy((char *)dct_wifi_config->stored_ap_list.security_key,
entry->password,
sizeof(dct_wifi_config->stored_ap_list.security_key));
// security type
dct_wifi_config->stored_ap_list.details.security =
(entry->security) ? WICED_SECURITY_WPA2_AES_PSK : WICED_SECURITY_OPEN;
// bss type
dct_wifi_config->stored_ap_list.details.bss_type = WICED_BSS_TYPE_INFRASTRUCTURE;
// band
dct_wifi_config->stored_ap_list.details.band = entry->band;
// write the image back and release the read lock
wiced_dct_write( (const void*) dct_wifi_config, DCT_WIFI_CONFIG_SECTION, 0, sizeof(platform_dct_wifi_config_t) );
wiced_dct_read_unlock( dct_wifi_config, WICED_TRUE );
DCT
Wifi+Bluetooth
Wireless MCU
I've run some searching for you.
I believe the internal function "wiced_join_ap_specific" is the actual function that WICED uses to join the stored APs, which is listed in '43xxx_Wi-Fi/WICED/internal/wifi.c'. I quote it here:
wiced_result_t wiced_join_ap_specific( wiced_ap_info_t* details, uint8_t security_key_length, const char security_key[ 64 ] )
#endif
wiced_result_t join_result = WICED_STA_JOIN_FAILED;
wiced_scan_result_t temp_scan_result;
#ifndef WICED_USE_WIFI_TWO_STA_INTERFACE
wiced_interface_t interface = WICED_STA_INTERFACE;
#endif
char ssid_name[SSID_NAME_SIZE + 1];
memset(ssid_name, 0, sizeof(ssid_name));
memcpy(ssid_name, details->SSID.value, details->SSID.length);
WPRINT_WICED_INFO(("Joining : %s\n", ssid_name));
memcpy( &temp_scan_result, details, sizeof( *details ) );
/* Try join AP with last know specific details */
if ( !( NULL_MAC(details->BSSID.octet) ) && details->channel != 0 )
join_result = (wiced_result_t) wwd_wifi_join_specific( &temp_scan_result, (uint8_t*) security_key, security_key_length, NULL, WICED_TO_WWD_INTERFACE(interface) );
if ( join_result != WICED_SUCCESS )
wiced_security_t security;
security = details->security;
if (details->bss_type == WICED_BSS_TYPE_ADHOC)
WPRINT_WICED_INFO(("%s: Network is ADHOC\n", __FUNCTION__));
security |= IBSS_ENABLED;
/* If join-specific failed, try scan and join AP */
join_result = (wiced_result_t) wwd_wifi_join( &details->SSID, security, (uint8_t*) security_key, security_key_length, NULL, WICED_TO_WWD_INTERFACE(interface) );
if ( join_result == WICED_SUCCESS )
WPRINT_WICED_INFO( ( "Successfully joined : %s\n", ssid_name) );
#ifdef WICED_USE_WIFI_TWO_STA_INTERFACE
wiced_sta_link_up[interface] = WICED_TRUE;
wiced_sta_security_type[interface] = details->security;
#else
wiced_sta_link_up = WICED_TRUE;
wiced_sta_security_type = details->security;
#endif
wwd_management_set_event_handler( link_events, wiced_link_events_handler, NULL, WICED_TO_WWD_INTERFACE(interface) );
return WICED_SUCCESS;
else
WPRINT_WICED_INFO(("Failed to join : %s\n", ssid_name));
return join_result;
As you can see, the variable "details" in this piece of code could represent the one named "details" in your code because they are of the same type wiced_ap_info_t. In this code we should see that, though you had setup the band with the line "dct_wifi_config->stored_ap_list.details.band = entry->band; ", it's never used when it actually tries to join a certain AP throughout this function.
So that's why it didn't work because the joining procedure didn't require the field "band". And I believe this is the answer.
Sincere regards from C. L.
