I have been using the config_mode snip as a pattern for building my own application. Unfortunately, I can't get config_mode to work the way it is supposed to. Upon entering a password and joining a network on scan_page_outer.html, the thing never actually connects to the router.
I have been able to get it to connect to the router using demo.appliance, so I know it's possible.
Can someone confirm that snip.config_mode either works or is broken when connecting to an access point using the scan method?
I'm using 2.4.1.
SPI
This is still a problem for me. Can anyone confirm that the sample code either works or does not work in the question above?
I could run snip.config_mode and connect with the AP by scan method.
Hello, As I assumed, the snip.config_mode should work and it is not broken.
I confirmed the API used in the demo.appliance is same as the one used in snip.config_mode.
Please check the API wiced_configure_device().
Let us know if you have any luck.
Please open a new discussion if you have an update.
