I'm trying to run the AWS Free RTOS Hello World example for the CYW943907AEVAL1F
So I Followed the instructions here https://www.cypress.com/video/amazon-freertos-101-cywxx907-lesson-4-afr-hello-world
I've Installed
- WICED Studio 6.4
- MAC OSX 10.15.6.
- Java 1.8 64bit
Cloned the Free RTOS repository using: git clone https://github.com/aws/amazon-freertos.git --recurse-submodules
set the WICED SDK path on /etc/profile to the only folder I could find for WICED STUDIO
an the commands perl platform_adjust_make.pl and chmod +x make on the freertos/vendors/cypress/WICED_SDK
Import the demo project
tried to build it and I've got this error
23:26:56 **** Build of configuration Default for project aws_demos ****
/amazon-freertos/vendors/cypress/WICED_SDK/make demo.aws_demo-CYW943907AEVAL1F-FreeRTOS-LwIP download run
Unknown host
Linux32 uname: ""
Linux64 uname: ""
OSX uname: ""
Win32 uname: ""
I could only found a old post from 2014 that relates this issue to the SDK
Any idea how to solve this issue?
thanks
ispn:38946:1:0
l1:314:1:0
This error appears when the environmental variable, WICED_STUDIO_SDK_PATH, is not defined. Please set WICED_STUDIO_SDK_PATH to /Users/your-username-here/Documents/WICED-Studio-6.4/ (default SDK directory).
To do this, in WICED Studio 6.4, go to Project -> Properties -> C/C++ Build -> Environment.
Hit Add... on the right side of the pane.
Set Name to WICED_STUDIO_SDK_PATH
Set Value to /Users/your-username-here/Documents/WICED-Studio-6.4/
Hit Ok -> Apply -> Ok
This should fix it. Feel free to let me know if there are further issues. Thank you for your patience.
Many thanks. That solved the issue. !
-Pablo
