Wi-Fi Combo Forum Discussions
I build a project that just need BCM94343W_AVN to send ethernet packet direct to SPI. And my MCU receive from SPI handle TCP/IP. So what should i modify on WICED-SDK. I am confusing with LwIP , NetX, or this function to get the raw packet have already had in WICED-API. Please help me
JaeyoungY_71
Hello Vinh,
I'm not sure if I understand  you correctly. Could you clarify a bit please? Where are you getting this packet from?
If you are talking about capturing raw wifi frames, you can do that with our monitor mode. This can be enabled by wwd_wifi_enable_monitor_mode(). Take a look at WICED-SDK-3.5.2\WICED\internal\wiced_cooee.c for the usage.
Jaeyoung
Hello jaeyoung
To be clear, my question is to bypass the MCU STM32F411 on BCM94343W_AVN, and the RAW ethernet packet (include MAC,IP address, Protocol...)can transceiver  by SPI with my external MCU.
