- Email to a Friend
Hello
to everybody.
I'm developing product using CYW954907AEVAL1F
Have I to buy my MAC address and VID ?
WICED Studio Wi-Fi Combo
- CYW954907AEVAL1F
- Email to a Friend
If you've larger chip volumes then purchasing the MAC address makes sense. If you've lesser chip volumes, I would suggest purchasing the MAC address won't be that profitable. You can go ahead with the pre-programmed MAC address in this case. You can get in touch with Murata on how to purchase the MAC address as the pre-programmed address belongs to them.
Aditi
- Email to a Friend
Yes, you can go ahead and buy the MAC address that is already pre-programmed into the chip. If you want a custom MAC then you can check with the IEEE. Please refer to the following link -
https://standards.ieee.org/products-services/regauth/index.html
Can you provide more info/clarification on the VID part?
Aditi
- Email to a Friend
How can I buy the MAC address that is already pre-programmed into the chip ?
I develop a firmware that use CDC-ACM as communication with USB .... Have I to buy a VID (vendor identifier) for my company ?
- Email to a Friend
Regard VID:
when we connect CYW954907AEVAL1F by USB on a Tablet
we want to display our string : "Gilardoni Raggi X - our product name".
This string is visible in
apps/snips/usbx_usb_device/usb_device_cdc_acm_read_write/usb_device_cdc_acm_read_write.c
row 312 :
unsigned char string_framework[] = {
/* Manufacturer string descriptor : Index 1 - "Cypress Semiconductor" */
0x09, 0x04, 0x01, 0x15,
0x43, 0x79, 0x70, 0x72, 0x65, 0x73, 0x73, 0x20,
0x53, 0x65, 0x6d, 0x69, 0x63, 0x6f, 0x6e, 0x64,
0x75, 0x63, 0x74, 0x6f, 0x72,
/* Product string descriptor : Index 2 - "Cypress USB UART" */
0x09, 0x04, 0x02, 0x10,
0x55, 0x53, 0x42, 0x20, 0x55, 0x41, 0x52, 0x54,
/* Serial Number string descriptor : Index 3 - "0001" */
0x09, 0x04, 0x03, 0x04,
0x30, 0x30, 0x30, 0x31
Can we change this string using Cypress-VID without buy our VID ?
- Email to a Friend
You can go through the following link to get more idea on VID/PID
Aditi
- Email to a Friend
Aditi
