hi
i am trying to download using ota fr example, but i got message which is " Error setting application size".
Download does not work.
i am using sdk version 3.1.2,  bcm9wcdusi09 module and WM-N-09_EVB.
serial flash is "SST25VF080B" and 8Mbit.
do you konw how to handle this?
thanx
Hey,
Have you been able to fix the issue?
A newer version of the SDK is now available and you may want to check it out.
The link to the SDK is here.
Kindly let us know if you have any questions.
Ab
