10:38 AM
May 11, 2017
10:38 AM
I am trying to communicate with wiced sense 2 from wiced IoT starter kit which has 94343w chip. My goal is be able to send ble data to wifi. I am using bt_smartbridge demo code but it did not work on ble side. I modified the BCM94343W_AVN.mk under the platforms/BCM94343W_AVN as follow and I use WICED SDK 4.1
BT_CHIP := 4343W (modified; was 43438)
BT_CHIP_REVISION := A1
BT_MODE ?= HCI
BT_CHIP_XTAL_FREQUENCY := 37_4MHz
Is it correct? I guess I might need the correct bluetooth firrmware binary bin file for 4343W. The wifi functionality works except ble.
Thank for your help and best regards
Labels
AWS
softAP
Wifi+Bluetooth
