09:53 PM
Jul 13, 2015
09:53 PM
Hi. All
I got bcm4390 gpio pin interrupt issue. I applied the example "client2ap and push2scan " to test gpio interrupt pin in my bcm94390 project.
but the gpio interrupt pin does not work.
the both example use the function "gpio_keypad_enable". In debug I checked when the key pressed, "gpio_keypad_enable" function
call "gpio_interrut_key_handler", but in the fucntion "gpio_interrut_key_handler" gpio_key_internal_t* key is NULL. And did not work.
I use GPIO A8 for interrupt . I want to use the function "gpio_keypad_enable".
Plz can anyone take a look at this. And GPIO PB can be used in bcm94390WCD2?
Labels
GPIO
Interrupts
