Using IOT Starter Kit based on BCM4343W.
We are planning to run the WICED Sdk 3.5.2(MFI certified) on this platform, to make use of the extensive libraries the SDK provides.
we are trying to run the WICED SDK on the STM32F407VG(Discovery board). We were able to flash the bootloader, DCT and the application images using the STlink JTAG. When the system boots, the bootloader is running, but the app  is not getting called from the bootloader code. I would appreciate, if you can help us with this situation.
We have followed the same steps as per below link, but not able run the Application Code.
https://community.broadcom.com/thread/2869?q=STM32F407VG%20Discovery%20board?
https://community.broadcom.com/community/wiced-wifi/wiced-wifi-forums/blog/2015/01/02/sn8000-wifi-mo...
I am attaching pdf document which explains the steps that we followed to bring up the STM discovery board.
I am attaching logs that we get while building and flashing.
Kindly help on the solution for the situation mentioned.
Jagadish
MichaelF_56
The MFi/HomeKit SDK is separate from the standard SDK, version 3.5.2
seyhan​ created the blog you are referring to for the SN8000.  I'm not sure if anything similar has been created/tested for the Avnet IoT Starter kit?
vik86peter_fennandrew997
Hi sheyan,
can I know SDK version for MFi/HomeKit.
The Link Mentioned below is relevant Procedure for setting up as reference.
we are using Avnet IOT starter kit.
regards,
Jagadish
You will need to send you six digit MFi account number to the user gangi​ and he will validate your account against the Apple licensing database. Once validated, he will add you to the private space where the latest HomeKit/MFi SDK is located.
