I’m trying to add usb host on CYW943907AEVAL1F reference CYW943907AEVAL1F USB Host Application Explained .But I have not distribution IC. so:
Pull WICED_USB_HOST_POWER_ENABLE pin low through a 10k resistor (based on the pin defined in platform.h)
Pull WICED_USB_HOST_OVERCURRENT pin high through a 4.7k resistor (based on the pin defined in platform.h)
Log:
+ USB20 Host HID Mouse Class Application +
> USB20 Host init starting...
Detected board strapping is in USB-PHY mode!!
Detected board is in USB Host mode!!
USB Host support 2 HCI resource
USB20 Host init completed!!!
hid_mouse
+++START: hid mouse test
Please plug in USB mouse...
(plug in usb mouse...and... the board reboot...)
Does anyone have any suggestions?
WICED Studio
Wireless MCU
Replace the start_GCC.S file provided in WICED/platform/MCU/BCM4390x/start_GCC.S and use the one provided here.
