We have a new project with omnivison camera sensor OV5640. now we searching a wifi controller for sharing image data. We found your product CYUSB3065 as MIPI interface to USB converter. Can you suggest any usb to Wifi IC's? or any more feasible way of the design?
Wifi+Bluetooth
Wireless MCU
Just to add to previous reply From Winston:
You need to use CYW43907 as USB Host to connect to CYUSB3065. There are USB drivers already in WICED-Studio for CYW43907. But you have to write USB Video class driver (UVC) to receive the data. You also need to do JPEG encoding (probably port libjpeg or some other encoders) depending upon your application needs.
Have a look at CYW43907. It has a USB 2.0 Host & Device capabilities. You will have to do the math for the possible Frame Rates etc. in case you plan to stream.
Some links:
http://www.cypress.com/file/298236/download
CYW943907AEVAL1F Evaluation Kit | Cypress Semiconductor
https://electricimp.com/docs/hardware/resources/reference-designs/imp005breakout/
Hope this helps.
Winston
Winston
