My question is similar to this one but I would like to build a Wifi to SDIO adapter.
I understand how to send/receive data via TCP/IP. However, I am unsure how to set up and transfer to/from the SDIO interface.
- How do I specify SDIO (not SPI etc) as the bus interface? I don’t see any bus definition in CYW943907AEVAL1F.mk
- How do I use the SDIO bus? Do I need to just wiced_init, and run the internal thread? Or do I need to directly use the wwd_bus interface to send/receive?
Many thanks in advance
Wireless MCU
The library functions for SDIO bus are described in /WICED/platform/MCU/BCM4390x/peripherals/platform_sdio.h. You can use platform_sdio_host_init() to initialise the SDIO interface.
Can anyone help me with this?
Are there any examples for how to use the platform_sdio interface in a practical program? E.g. reading/writing using the interface, setting block size, master/slave, etc?
