I want to make an application which uses wifi continuously on with BT/BLE switching for Voice and Data communications. So, I want Combo module of wifi with Dual mode Bluetooth BLE5 so that i can achieve the same in my product as i am unable to find this kind of module as of now so I would like to request all that if you have seen or using this kind of module then please suggest us.
I have found one solution CYW43438 but its BLE 4.2 so i want the same with BLE 5 . Also please share the link for the same to buy as i didnt find the way to buy this modules.
Tell me if you need more info.
Thanks & Regards,
Irfan
Hi Irfan,
Unfortunately, we do not have a combo chip with BLE 5.0 as of now. However you can use BT chip CYW 20719 with BLE 5.0 feature.
For the application you described, you can use Cypress combo chips CYW43438, CYW4343W, CYW43455. More details here: http://www.cypress.com/products/wi-fi-bluetooth-combos
To purchase any chip or module, please contact your local Cypress Sales team or distributor. Or you can check the Cypress Store option on Cypress Website: http://www.cypress.com/cypress-store
Sheetal
