Wi-Fi Combo
I want to make an application which uses wifi continuously on with BT/BLE switching for Voice and Data communications. So, I want Combo module of wifi with Dual mode Bluetooth  BLE5 so that i can achieve the same in my product as i am unable to find this kind of module as of now so I would like to request all that if you have seen or using this kind of module then please suggest us.
I have found one solution CYW43438 but its BLE 4.2 so i want the same with BLE 5 . Also please share the link for the same to buy as i didnt find the way to buy this modules.
Tell me if you need more info.
Thanks & Regards,
Irfan
SheetalJ
Moderator 750 replies posted 500 likes received 500 replies posted
Hi Irfan,
Unfortunately, we do not have a combo chip with BLE 5.0 as of now. However you can use BT chip CYW 20719 with BLE 5.0 feature.
For the application you described, you can use Cypress combo chips CYW43438, CYW4343W, CYW43455. More details here: http://www.cypress.com/products/wi-fi-bluetooth-combos
To purchase any chip or module, please contact your local Cypress Sales team or distributor. Or you can check the Cypress Store option on Cypress Website: http://www.cypress.com/cypress-store
Sheetal
MichaelF_56
Moderator 250 sign-ins 25 comments on blog 10 comments on blog
Which optional features are needed from BT 5?  Unfortunately, none of our current BT Combo modules support any of the 3 optional features, but all will be certified under BT 5 (no optional features).  We have a new Combo coming in the first portion of Q1'19 that will support 2Mb/s PHY.
SheetalJ
Hi Irfan,
Sheetal
