Wiced debug not working
BaGo_4138971
Hi All,
I tried to debug wiced source code (SDKv6.1), some time it works but some time it won't.  When it stop working i need to delete metadata folder and reopen workspace.
Since metadata folder is delete, my debug configuration also deleted. So i need to set it again.
Please help me to understand and solve the problem. I have attached screen shot, Please check.
Basava.
Please follow the attached document for setting the debug configurations again.
You need not delete the metadata dir if the debug doesn't start for some reason. You can just terminate and launch the debug session again.
BaGo_4138971
Any solutions for above problem, its frustrating to create workspace again and again.
Please suggest any solutions.
Basava.
BaGo_4138971
Is anybody faced this problem?  any solution for this problem?
Basava
As I checked my WICED studio that is ver 6.2,
there is not "4343xxx_Wi-Fi_Debug_Windows" as follows.
My platform is Windows10(x64).
Could you tell me which setting should I set?
Thank you.
--TAK
You can create 43xxx_Wi-Fi_Debug_Windows under GDB by double clicking the  GDB hardware debugging
