DaEr_349131
25 likes received 50 sign-ins 5 comments on KBA
Hi all,
Is it only me, but I don't seem to find the latest Wiced 3.x SDK installers for Mac.
I can see the 2.x installer, but that's it.
As it's just make and eclipse, is there a git-repo where we can pull the actual SDK source-files from instead of using those ".macapp/.exe" installers!?
Thanks David
There are always 7z archive with full source of each SDK reelase, so you shouldn't have trouble importing a new version. But afaik, there is no repository to pull from.
MichaelF_56
Here's the last version we published with an installer for OSX: WICED Software Development Kit 3.1.2
You can install it, then use the process here which leverages the .7z archive from a newer version to upgrade: How to import a WICED SDK into an existing WICED Eclipse IDE (2)
Thanks for reply! That's great. Better separate Eclipse from the actual SDK source files.
please consider a github, gitlab repo for the source-code as it would greatly help provide patches, issues and track changes
