Wi-Fi Combo Forum Discussions
RoMc_863046
25 sign-ins 10 replies posted 10 sign-ins
I have shared code that has some compiler specific blocks.
I am looking for pre-defined compiler macros in Wiced.
GCC typically uses:  __GNUC__
ARM uses: __CC_ARM
What does Wiced use?  My platform is the Cypress CYW4343W, STM32F4
RoMc_863046
There are zero occurrences of ARM_GNU defined.
I'll just make my own:
#define __WICED_SDK__
I though I could use something that was already common but this will work too.
-Rocko
YashM
First question asked 250 sign-ins 100 replies posted
Hi
WICED uses ARM_GNU -> you can check the ARM_GNU related files under C:\<installation directory>\WICED-Studio-6.x\43xxx_Wi-Fi\tools\ARM_GNU\Win32.
"I have shared code that has some compiler specific blocks" -> if you have attached any files then it has not come up, please attach it again.
Thanks and regards
RoMc_863046
-Rocko
