On WICED-SDK-3.5.1, I see that the callbacks for up or down are not working reliably.
for snip.link_status: after you register callbacks and bring up STA.
/* Register callbacks */
wiced_network_register_link_callback( link_up, link_down, WICED_STA_INTERFACE );
/* Bring up the STA (client) interface ------------------------------------------------------- */
wiced_network_up( WICED_STA_INTERFACE, WICED_USE_EXTERNAL_DHCP_SERVER, NULL );
/* Initialise semaphore to notify when the network comes up */
wiced_rtos_init_semaphore( &link_up_semaphore );
I see that when you bring the AP down, the link down status callback only gets pushed out to subscribers upon a subsequent bring up of the AP?
Which device and platform are you running this on? Can you try sdk 3.6.0 which should be in the same place you got 3.5.1 from?
Hi.
We are using the ISM43341 Inventek's module. I can try the 3.6.0 SDK.
let me get back on this.
Thanks!
Adding the Inventek technical team santol dickb als@inventeksys.com
Hello
Hoping to check in with you on your progress and general status.
Thanks!
Al
Al Serpa
Inventek Systems
- www.INVENTEKSYS.com
2 Republic Road
Billerica, MA 01862
978-667-1962 Office
978-667-1949 Fax
