lola_1650581
First like received
Hi,where can I download the document about SB-WBM-N07P1 module.About the module ,is that the wifi and BT  use the same antenna,or they all have there own antenna
MichaelF_56
What partner makes this module?  Resembles a USI part number. Have you talked to the partner, or maybe the distributor that you are working with?
