Wi-Fi Combo Forum Discussions
GaAn_541926
First like given
Cypress Support Community:
Does anybody know where to find documentation that explains how WICED works?
For example: where is the API document for WICED_RTOS ?
If WICED_RTOS works well, why do we need to have either ThreadX or FreeRTOS options ?
Where is the document or API for "socket io" functions ?
Where is the document that explains how to perform a TLS handshake ?
Where are the documents that assist with connections to Azure ?
There are many more questions, but let's start with these.
Thanks, Garry Anderson.
MuraliR_36
250 sign-ins 250 replies posted 100 solutions authored
Hi
--> Unfortunately, there's no specific document that deals with this. If you face any issues during any implementation, do let us know and we will assist you.
Where is the API document for WICED_RTOS ?
--> There's a html documentation under /43xxx_Wi-Fi/doc called API.html
You should be able to find all API documentations under this.
Also this video course has a brief introduction to RTOS : https://www.cypress.com/training/wiced-wi-fi-101-chapter-3-wiced-rtos-features
--> WICED_RTOS is implemented based on either ThreadX or FreeRTOS depending upon the requirement. WICED_RTOS is not a separate RTOS.
-->You should be able to find the documents in API.html under Cypress WICED API Reference Guide->Components->IP Communication-> WebSocket
--> Unfortunately, there's no specific document from Cypress that deals with this. The standard TLS handshake procedure is what is implemented in WICED.
--> Please do check out these Blog Posts : MQTT with Microsoft Azure Posting a Message to Azure IoT Hub
MuraliR_36
Hi
Hi Murali R 36:
Thanks for your reply.
I will check them out tomorrow.
Garry.
