Hello
           When I was doing usart data sent to the TCP encountered a problem:
           Somewhile ,when I  through the usart send “abcdefg”  to the BCM943362WCD4 , It can receive the data ”abc”. But it lost the data “defg”. And I send “abcdefg” to the BCM943362WCD4 again, It receive the data ”defgabcdefg”.Why is this?
            My English is not good, I hope you can understand ^_^ thx.
    while(1){
        while (wiced_uart_receive_bytes( WICED_UART_1, &c, 1, 1 )==WICED_SUCCESS )
            rxbuf[rxcount++]=c;
            readflag=true;
        if(readflag==true)
            wiced_tcp_send_buffer( &tcp_client_socket,rxbuf,rxcount);
            wiced_uart_transmit_bytes( WICED_UART_1,rxbuf,rxcount);
            memset(rxbuf,0,rxcount);
            rxcount=0;
            readflag=false;
Are you using ring buffer? One thing that catches my attention here is wiced_uart_receive_bytes() only waits for 1 millisecond. Try changing that to WICED_NEVER_TIMEOUT.
Yes,I am using the ring buffer.
I changed the WICED_NEVER_TIMEOUT=5 millisecond,it perfect to accept.
Thank you very much.^_^
Did you mean that you changed the timeout_ms argument from 1 to 5?
Please do not change the default definition of WICED_NEVER_TIMEOUT.
