An unexpected error occurred that if I use Defensics Software to change WPA(AES) handshake message,
then my example app(main.c) doesn't work for BCM943438WCD1.
WICED SDK: 3.3.1
Chip: BCM943438
Make Target: FreeRTOS-LwIP-SDIO
Example App Source Code: main.c
Example App Log: log.txt
Wireshark log: WPA-cap1.pcapng (Line 46 => Correct handshake message, Line 117 => Error handshake message)
Sorry. It is not clear as to what exactly you are trying to do here?
What is "Defensics Software"?
